oil burning question
Car: 86 iroc-z
Engine: 87 l98 383
I have an embarrassing amount of smoke at start up with my iroc. And while driving I can smell a little bit of oil but it smells more like its running rich. It also seems to smoke a little when I manually downshift my auto trans, as i've been told this by the my buddies that drive those POS mustangs.
But anyways I pulled the plugs and they were black with a little charcoal like buildup and dry as can be. So then I also pulled the valve covers off. The rockers seemed a little loose, I could wiggle them with little effort. I am just wondering if this is normal and if that could be the simple cause of the smoking. I understand that none of you are here to look at it but just curious if it would be a possibility. Thank you for you help!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil burning question
It's normal to be able to wiggle the rockers sideways. Try replacing your valve seals and see if your blue smoke on startup goes away.
Navy8125
Aug 21, 2015 09:32 AM
