Still have my problem.
Old Nov 30, 2007 | 04:36 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
well now im confused.
My car was acting up majorly so replaced a ton of parts.
Ive gone through and replaced all of my ignition system but the coil however i had my coil tested. I replaced my fuel filter, ran a bottle of fuel injector cleaner not sure on the brand it was a few weeks ago...
Its still chugging. any ideas??
You start up the car... then once you start driving you cant accelerate fast at all. you put it to the floor it dies... press it down a decent amount and it will like "Chug". Like it wont accelerate anymore. to get to 25 mph it takes me a complete block in town. other than that I'm not really sure how to explain it..I hope that helps some because i need to fix this problem soon.
parts all replaced within the last 3,000. I think first it went plugs wires, cap and rotor, then distributor, ign. module, then fuel filter. I think i'm forgetting something. TPS was replaced also.
I haven't checked injectors like changing them out. That maybe next to replace.
Any other parts that may have gone bad?
Old Nov 30, 2007 | 04:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What was done to it right before all of this started happening?
Old Nov 30, 2007 | 04:45 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Re: Still have my problem.
well the ignition started screwing up then ended up dying so all of the ignition was gone through and replaced. i was getting the check engine for quite some time for the TPS so fixed that to get the light off.
the problem ive had for awhile but it never was bad. It happened like once or twice a week well backing up... Now its to the point were i cant get anyplace in a hurry because it does it. Constantly.
Old Nov 30, 2007 | 06:18 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You really need to hook a scanner up to it so you can see what all the sensors are reading. Otherwise you're just shooting in the dark. You might try unplugging the MAF and seeing if it runs better without it (bad MAF if it does).
Old Dec 1, 2007 | 01:08 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
just and idea my wifes cougar did something like this and we had to replace the fuel pump
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcbitchman
Sep 29, 2015 12:32 AM
383cam
Sep 9, 2015 06:01 AM
