Battery wont charge...
Old Dec 3, 2007 | 01:18 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
Ok so when I crank my car it drains the battery and then I have to charge it again. I took the alternator off and took it to work (I work for O'reilly Auto Parts) and tested the alternator and it tested "Good" and the Battery is brand new so I charged it up, and that didnt work
I checked every fuse and none of them are blown
What happened: I was removing my valve cover and repeatedly hit the power terminal on the alternator and sparks flew and one time even a huge spark and alot of smoke came off the alternator
Will the Alternator still test good if something was wrong with it? The battery is brand new
Old Dec 3, 2007 | 01:58 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Battery wont charge...
Check the wires between Battery, Starter and Alt, also there is a fuse for electric fans that i have read people blowing that will make the Alt not charge.
Old Dec 3, 2007 | 02:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Some cars have a fusable link between the alternator and battery.
Old Dec 3, 2007 | 06:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If it will start and run, put a volt meter across the battery terminals and see what the reading is - if its over 13.5V, then it is charging Should be over 14V, but even 13.5 is good enough for this. If not, then you know the problem.
Now, if it is charging, check the battery terminals and cables (both ends of the cables, and the mount at the block and starter) to check for anything that might make for a poor connection - corrosion, paint, oil, rust, etc.
If thats OK, have your battery load tested after you charge it. Don't just do it once - even most BAD batteries will pass with one load test. If the battery is good, it will pass 3 or 4 consecutive load tests. If it can't, its probably a dud.
If the alt and battery check out, it may be a starter issue or it could be in the wiring.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
