car dies when accelerates
Old Dec 3, 2007 | 10:10 PM
danny14gnx's Avatar
Its an 88 gta 305 tpi and it just died at a intersection if it idles for to long it just slowly dies if i let it sit for awhile it'll run fine for about 5 minutes then just slowly looses power again im pretty sure its a fuel problem and im thinking the pump anyone else got any clues?????
Old Dec 4, 2007 | 09:23 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: car dies when accelerates
I agree with you, I'd start by checking your fuel pressure with a gauge and take it from there. My car did something similar a few years back, and it was the pump.
Old Dec 4, 2007 | 09:58 AM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
also check for vaccum leaks and clogged fuel filter
Old Dec 4, 2007 | 01:49 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
danny14gnx,
I would agree to check the pressure on your fuel line. The tpi system typically runs at 43-45 lbs. When was the last time you changed out your fuel filter? That could also hinder the proper flow of gas.
If those don't lead to the problem pull some plugs and check to make sure they aren't fouled up. I had the same problem a long time ago because I just ran my plugs for too long!
Post what you find,
Rabi C.
Old Dec 4, 2007 | 10:02 PM
danny14gnx's Avatar
well ran it today and i think after it cooled down it went away but its up for sale so im not going to bother with it aint got the time or money for it thanks anyways
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
