IT'S ALIVE. BIG THANKS.
Old Dec 4, 2007 | 08:53 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
just a big thank you to all here that helped with all the great info and tips. this was my first bottom up rebuild, ( pistons, rings, bearings, bore, ect.). there is no better feeling in the world when you turn the key and it starts up and runs the first time. especially when you did all the work yourself, except the machine shop work of course.
thanks to all, happy hollidays.
p.s. to all who think they cant do it, if i did any one can.
Old Dec 4, 2007 | 12:10 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: IT'S ALIVE. BIG THANKS.
What did you use to cover up the heater box ??
Old Dec 4, 2007 | 12:50 PM
SPIKE's Avatar
Car: 86 CAMARO
84, found a partial roll of galvenized roof flashing like 24 gauge or so in the trash pile next to a new house they were building. i used a pair of tin snips and some pop rivets then sprayed the whole firewall with undercoating in a can. kind of blended everything in. one mans trash is another mans treasure.
Old Dec 4, 2007 | 04:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's a downright LONELY engine bay. No powersteering? Electric fan?
It ran the first time?!? Beginners luck!
Rock on Spike.
Old Dec 4, 2007 | 05:21 PM
SPIKE's Avatar
Car: 86 CAMARO
sonic, i want to thank you personally for all your help. see the 3 studs at the bottom of the pic, thats whats holding my getto fab electric fan and that ice cube relay where my msd ignition box should be,( ive been good all year santa.) thats the fan relay. and yes no power steering.
Old Dec 4, 2007 | 06:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
ha, that's 2 more studs than i'm using to hold on my electric fan. (a single 10-32 machine screw).
So, how's it run?
Old Dec 5, 2007 | 07:06 AM
SPIKE's Avatar
Car: 86 CAMARO
have not got a chance to stomp on it yet but man it sounds nasty with the tru duals. i only got a couple laps around the block to seat the rings and get the tranny heated up to top off the fluids. but man she feels like she wants to go. big difference from before ( 3 pistons with broke ring lands). hopefully this weekend ill get her dialed in.
cheesehomer
Dec 31, 2015 08:48 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
redformula88
Oct 14, 2015 06:08 PM
skinny z
Oct 5, 2015 06:23 PM
gta892000
Sep 16, 2015 12:37 AM
