Cold + Camaro = No startup?
Old Dec 7, 2007 | 08:09 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
First winter with the z28. 5.0L TPI, hasn't dropped below 15F. Couldn't start her last night. Today after school it took me 10 tries to get her running... I had to rev it up.
It would turn over, idle for 5 seconds and die. So I had to rev it till it warmed up or is there a bigger problem?
-Peace
Old Dec 7, 2007 | 08:20 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: Cold + Camaro = No startup?
umm sound like the cold start injector isnt working...
Old Dec 7, 2007 | 08:23 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
hey ,, ive got a 350 in my car , its also carbd an its gotten to about 4 degrees out an its fired over every time ,, is you altenator bad ? , how about your battery ? was their still power after it died ,did the lights get dimmer at all ? it kinda sounds like a possible bad battery to me
or like alpine said
Old Dec 7, 2007 | 08:44 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
I got the battery last winter, new alternator last winter... whats a cold start injector?
lights work fine and don't dim...
Old Dec 7, 2007 | 09:38 PM
alpine247's Avatar
Car: 1988 IROC-Z
its the 9th injector
basically it is a electronic fuel-injection that supplies extra fuel to the engine for cold starting.
Old Dec 7, 2007 | 09:42 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
really? it is hard to install? how much do they run...
thanks
Old Dec 7, 2007 | 10:12 PM
alpine247's Avatar
Car: 1988 IROC-Z
nope not hard at all to install.
i think they run about 50-150 depends what brand u get.
here's what they look like..
http://www.partsamerica.com/ProductD...pe=475&PTSet=A
Old Dec 7, 2007 | 10:14 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Well, I had a horrible run in and needed to replace all my injectors so maybe this one got F'ed up too. Oh well, I don't plan on driving it in the winters so it's no big deal...
Old Dec 7, 2007 | 10:27 PM
alpine247's Avatar
Car: 1988 IROC-Z
im saying it could be this..
is ur engine light on??
Old Dec 8, 2007 | 08:33 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Yea my engine light is on, but its been on for awhile.
Old Dec 8, 2007 | 11:23 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The 92 TPI motor does not have a cold start injector.
Check the codes, that would be the first place to start.
Old Dec 9, 2007 | 01:29 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
How do I go about checking code? I heard some device was involved that I can't afford .
Old Dec 9, 2007 | 03:09 PM
Toehead's Avatar
HE CONNECTOR
| 1 2 3 -4 -5 -6 |
| 7 8 9 10 11 12 |
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12. No reference pulses to Electronic Control Module (ECM).
13. Oxygen sensor signal stays lean during warm engine cruise
14. High temperature indicated at engine coolant temp. sensor
15. Low temperature indicated at engine coolant temp. sensor
16. High battery voltage OR
Direct inition system open or shorted to ground
17. RPM signal problem
18-20. N/A
21. High voltage at throttle positon sensor
22. Low voltage at throttle positon sensor OR
Fuel cutoff relay circuit open or shorted to ground
23. Low temperature at manifold air temperature sensor OR
Throttle position sensor error
24. Circuit fault in vehicle speed sensor
25. High temperature at manifold air temperature sensor OR
Vacuum switching valve circuit open or shorted to ground OR
High voltage at ATS sensor
26. Fault in quad driver module
27. Fault in 2nd gear switch
28. Fault in 3rd gear switch
29. Fault in 4th gear switch
30. N/A
31. Low voltage at manifold absolute pressure sensor OR
Fuel injector OR
Park or neutral switch OR
CAM diagnostic OR
Governor malfunction OR
Wastegate overboost OR
Wastegate eletrical signal open or shorted to ground
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35. Idle speed can not be set to desired RPM
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
37. N/A
38. Fault in torque converter clutch brake switch
39. Fault in torque converter clutch circuit
40. N/A
41. Fault at cam sensor OR
Cylinder select error OR
Tach input error
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
44. Oxygen sensor lean
45. Oxygen sensor rich
46. Fault at vehicle anti-theft sytem OR
Fault at power steering switch
47. Problem at Electronic Control Module (ECM)
48. Misfire
49. Vacuum leak
50. N/A
51. PROM error
52. Problem at Electronic Control Module (ECM) -
Missing fuel calpac missing OR
Analog to digital converter error OR
Fault at quad driver module OR
Low voltage at oil temperature sensor
53. High voltage at battery OR
High voltage at exhaust gas recirculation valve OR
Voltage reference error OR
Problem at vehicle anti-theft system
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
55. Problem at Electronic Control Module (ECM) -
ECM failure OR
Serial bus error OR
Fuel lean malfunction
56. Low coolant or corrosivity OR
Fault in port throttle system vacuum sensor
57. N/A
58. Problem at vehicle anti-theft system
59-60. N/A
61. Oxygen sensor degraded OR
Port throttle system error OR
Cruise control problems
62. Gear switch input diagnostics OR
High voltage at oil temperature sensor OR
Fault in cruise control- vacuum solenoid circuit
63. High voltage at manifold absolute pressure sensor OR
Fault in exhaust gas recirculation valve OR
Fault at right oxygen sensor
64. Low voltage at manifold absolute pressure sensor OR
Right oxygen sensor lean
65. Failure at exhaust gas recirculation valve OR
Faulure at injector peak/hold diagnostic OR
Right oxygen sensor rich OR
Fault at cruise control position sensor
66. Internal reset of Electronic Control Module (ECM)
67. Fault at cruise control switch
68. Fault at cruise control switch
69. Fault at air conditioner pressure switch
70-87. N/A
88. Internal reset of Electronic Control Module (ECM)
Old Dec 9, 2007 | 09:05 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Thanks...
So I run a wire from 6 to 12, to 5 - 6?
Then it will display these numbers and those are the problems? Or is it more complicated then that?
jklein337
Sep 19, 2018 06:23 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
