Self aligning rockers for cam 6000-6300 rpms?
Old Dec 8, 2007 | 05:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I have Comp Magnum 1.6 rockers that are self aligning for my L98. I want to know if i should change over to guideplates and NSA rockers when i throw a cam in this motor. plan to spin to no more than 6200rpms or so.
Is there more saftey/control with guideplates at this rpm range?
Old Dec 8, 2007 | 06:08 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: Self aligning rockers for cam 6000-6300 rpms?
I'm not running guide plates in mine and I have a .481 intake and .496 exhause valve lift with my roller cam and the 1.6 rockers. I have been known to 6500+ rpms and have not had any problems as of yet.
I will say its better to have for the extra support.
Old Dec 8, 2007 | 07:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if i can get away without it that will be fine but i have no problems purchasing new ones and selling off these ones i have now
i'm thinkin of running either the 224/230 cam with .536/.544 lift or the 230/236 cam with w/e that lift works to be with 1.6's..probly .540/.550 ish
Old Dec 9, 2007 | 12:21 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't think there's any reliability difference between the two. SA rockers are stock for anything newer than 1987, ergo 4th gens use them. I imagine many are modified and running higher RPMs, so I wouldn't sweat it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
