Blown head gasket?
Blown head gasket?
I've noticed that I blow quite a large amount of smoke/mist out when I start cold start the car. Once the motor is warmed up the smoke goes away. I don't smell any odor, I do see a "wet spot" on the ground under the tailpipe.
Could this be coolant spilling over and burning off?
BTW my car is an EFI to carb conversion if that has anything to do with it.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Blown head gasket?
That's just condensation. Welcome to winter
Completely normal.
Completely normal. Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Water coming out of the tailpipe is a byproduct of combustion. It's usually an indicator of a good air/fuel mixture.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
