Highway RPM's
Old Dec 10, 2007 | 06:49 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
Highway RPM's
How can i figure out what my highway rpm's will be at 70 mph with my 4 speed, 3.23 gears, and a 29 to 29.5 inch tall tires would be?
Old Dec 10, 2007 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Highway RPM's
70 mph * 63360 inches/mile / 60 seconds/minute / (29" tire dia * pi) * 3.23 * whatever overdrive ratio your transmission has.
Old Dec 10, 2007 | 07:16 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: Highway RPM's
sweet, thanks. i guess i should be runnin about 2600 rpm then.
Old Dec 11, 2007 | 12:13 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Highway RPM's
say 60mph, with 26.5" tall tires, 3.27 rear gears, and a 700r4 (is it .67 or .70 overdrive ratio)
i got me a 1742 rpm at 60mph with .70 overdrive
and a 1667 rpm with .67 overdrive
prob is that im running 2000 at 60mph with the above. i believe my stall is alil more than stock(idk wat stock is) but i think its 1700-1800 stall
Old Dec 11, 2007 | 12:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Highway RPM's
The factory tach is known for its inaccuracy.
Old Dec 13, 2007 | 06:19 PM
Car: 87 TA clone
Re: Highway RPM's
ive tested it with a scanner as well, the tach is basically dead on... maybe 50-100 rpms off. i had the scanner connected when i did the test. also my car seemed to lose a bit of tq down low after i installed 3" mandrel bent exhaust with xpipe over my other 3" true dual compression bent dual exhaust no crossover on a basically stock 350tpi (in my sig). could that be the reason why my rpms are higher bc of the loss of tq? thats what im guessin.
i know the exhasut is overkill but i had to upgrade it bc it was too low and i was dropping the car with sportlines and its upgraded for my future 500hp 383 hsr.
sry heres my sig
Last edited by customblackbird; Dec 13, 2007 at 06:20 PM. Reason: Automerged Doublepost
Old Dec 13, 2007 | 06:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Highway RPM's
Are you sure your converter clutch is locking?
Old Dec 16, 2007 | 03:45 AM
Car: 87 TA clone
Re: Highway RPM's
i really didnt do anything to the trans, it was working before the exhaust swap. all i did to the trans was install billet 30% larger than vette servo and 50% larger than stock overdrive billet servo, new trans filter, new raptor blood fluid, deep pan, and new mega boost valve and low reverse boost valve.
i dont think u can affect the converter with those mods... can U?
any way to tell if the converter is locking up?
Old Dec 18, 2007 | 05:05 AM
sradams21's Avatar
Car: 1991 firebird
Axle/Gears: 10-bolt 3.08
Re: Highway RPM's
Customblackbird the stock overdrive for a 700r4 is 0.70.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
wisemanz28
Sep 20, 2015 01:26 PM
