I am 2 degrees ATDC
Old Dec 11, 2007 | 10:21 AM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
I am 2 degrees ATDC
Alright... My car was backfiring, and i thought it was the smog pump so i removed it, and it still backfires... then i looked at my timing mark and it was to the right of the 0, and after looking on here i see im at 2 degrees ATDC
Is the retarded timing the source of my backfire? Do I need to zero my timing out? or advance it a little BTDC? And rotating the dizzy clockwise is advancing right?
Old Dec 11, 2007 | 10:36 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: I am 2 degrees ATDC
Be carfull. That mark is not always the best thing to look at to determine timing. The inner hub and outter hub might have changed places over the years. The otter one can rotate sometimes. It might not have though.
Either way, I would say your backfire is due to your timing, but I don't think that following that mark will solve it all. You will need to TDC another way, then start from there.
Old Dec 11, 2007 | 01:16 PM
Car: 89 Camaro RS
Well i adjusted it to 2 degrees BTDC. And the Car is no longer backfiring.
Yay!
Dennis: my car has a 95-00 350 engine in it, Do you think since the engine is not real old that the timing mark may still be off a little bit?
Old Dec 11, 2007 | 01:54 PM
Engine: LS3
No, def not. That new a motor, should be totally fine. i have herd of them being off on new motors, but that has to be super rare.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ironbmt
Sep 27, 2015 06:00 AM
anesthes
Sep 21, 2015 10:24 AM
