Need Help! 88' Formula Problems
Car: 88' Formula
Axle/Gears: 3:73 LS
Hello everyone. I'm new to the forums, but not the birds. I'm Dave AKA daveysaun. The problem I'm having is I've got an 88' Formula, 305 TPI. Auto. Pretty stout as long as it's running. I've done the search thing and found similar problems but not exactly. If I let the thing sit for a couple of days I can go out and hit the key, and instantly fires right up. I'll drive it to work, 8 miles. Let it set for my 12 hr shift. And when I leave, hit the key, an wa wa wa no start for a couple of seconds (about 10 to be exact) and then it stumbles to life reaking of unburned fuel and smoking out the pipes. When I got it, she ran pretty good. Then one day I took off pretty hard, and let off the pedal, it felt like it was going to die. Like it was out of fuel. Had a quarter of a tank in it, so I added more and she ran fine but started doing what I described. I've done a complete tuneup, 8mm Taylor wires, NGK plugs. Accel cap, Accel rotor, and Accel module. Ran all new vacum hoses. No AIR pump. But it started doing this before I disconnected it. Also new fuel pump relay, fuel filter. IAC valve. Any input would be ap
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Need Help! 88' Formula Problems
I'm wondering about coolant temp sensor... Sometimes they go haywire and take longer to cool off than the engine.
Also, do you hear the fuel pump prime up before you crank it?
Car: 88' Formula
Axle/Gears: 3:73 LS
I'll try the CTS. But would that affect starting. I can hear the pump prime, so I know it's getting fuel.
Engine: 2.8/TBI/TPI
The other HUGE problem that reoccurs often is the MAF. MAF death is more common than you think.
I think the coolant temp is referenced during starting by the PROM. That, along with the MAF, and throttle position.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Could be a malfunctioning fuel injector.
theshackle
Mar 5, 2017 06:37 PM
