83 camaro problem stalls
Old Dec 14, 2007 | 01:23 AM
Impoundme's Avatar
Ok I have a 1983 Camaro berlinetta 5.0 v8.. when i attempt to drive it it bogs down when i give it gas and doesnt accelerate, after awhile it gets worse to the point where i have to constantly give it gas to keep it running.. it will stall on me after about 5 to ten minutes of running.. It doesnt just shut off either, it bogs down and idles real slow to the point where it just turns off. and it will start reight back up.. It has a brand new exhaust, battery and starter and getting a new alternator tomorow to hopefully fix it. what do you think the problem is?
and the repair place thats working on it is throwing in the alternator because they say it has weird voltage fluctuations or something like that and it may be causing it to die.. do you think there full of **** or is this possible?
Old Dec 14, 2007 | 08:48 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 83 camaro problem stalls
Sounds like a clogged Cat converter to me.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
92camaroJoe
Aug 13, 2015 06:07 AM
