New problem with the trans?
Old Dec 14, 2007 | 12:14 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I finally got my other problems worked out.....mostly. Then something new starts acting up. When I stomp the gas at a light or up a hill, something starts popping. There really isn't much of a sound as much as a feeling of popping. The car learches when it pops. I don't know anything about transmissions, but I kinda get the feeling that the rear end is skiping teeth or something. I have no idea where to start diagnosing the problem and once i figure it out i have no idea how to work on the drive train behind the engine.
There has always been a wierd sound coming from back there when i'm in gear and accelerating. It's a vibrating or maybe grinding low growl sound.
Thanks in advance for your ideas
Old Dec 14, 2007 | 12:29 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: New problem with the trans?
I would start by trying to isolate the sound. Have some one rev the car in park while you walk around it and listen. Do the same with them driving slowly and you walking beside the car. Another was is to put the car up on jack stands and put it in gear(very dangerous). You are going to have to be a lost more specific to get any kind of help.
Cooter
Old Dec 14, 2007 | 12:33 PM
RazorN8's Avatar
Car: 1987 camaro
You talking about the popping or the grinding? The popping only happens under hard acceleration and that's what i'm more concerned about. I guess i can try to find where the growl is comming from.
Old Dec 14, 2007 | 12:38 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
I just read your other post about the (oil) coming out your exaust. Question do you have low power and some times stalls at lights and stop signs, hard to start with out giving it gas? I think your cat may be clogged up, that could also be the poping/ ticking noise you hear.
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
