does anybody know
Old Dec 17, 2007 | 09:46 AM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
does anybody know
how much power and torque round about would a mid to late 70s smallblock 350 make??? i found one in a junkyard to get me by till i get my other engine built and was merely just curious
Old Dec 17, 2007 | 09:58 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: does anybody know
There are a lot of variables there. We need a few more details!
Old Dec 17, 2007 | 10:19 AM
A typical one such as might be found in trucks, full-size cars, Vettes, Malibus, Z28s, etc. (all the same...) made about 275 ft-lbs of torque, and about 165 HP with a 2-bbl carb or 180 HP with a 4bbl carb (again, same thing; just a different carb and intake stuck on top)
Pretty laughable, really.
Old Dec 17, 2007 | 10:48 AM
85T/A's Avatar
cool beans so in other words itll mkae more than my 305 that was made in 85 lol
Old Dec 17, 2007 | 11:13 AM
More torque, yes; more HP than some (LG4), less than others (L69)
It is THE DUNG.
OTOH, it's a 350; do away with the deep dish pistons and the smogger heads, so that the compression is higher than 8¼:1, and give it some flow, and put a better cam in it than the 929 POS the factory put in all of those, and yeah, you'll have something decent.
Put it in EXACTLY as you found it, you'll be pretty much underwhelmed.
I don't know what's so "cool" about one of those, except that maybe the block is a rebuildable core. That's about all that's worth anything. The rest is TRASH.
Old Dec 17, 2007 | 11:35 AM
85T/A's Avatar
well this 350 is opnly to get me by for right now.... right now im building another one
flat tops trick flow kenny duttweiler heads comp extreme energy cam grind number xs274 edlebrock performer rpm airgap intake msd ignition holley 750 double pumper hedman LTs 3000 stall
oh and btw i did have the lg4 lol.... and another curiosity..just for sake of converstion what would happen if i put my heads from my 305 on the 350?
Old Dec 17, 2007 | 11:53 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you would bump your compression up quite a bit however your intake and exhaust flow will most likely decrease considerably unless you put 1.94 valves in those heads and hog them out
i have run 4416 305 heads on a bored out 350 before and it runs damn strong but no top end past around 4k
you will hear alot of different things from ppl regarding this
and the 70s 350 engine s werent exatly performers by any means except in a few rare instances, they were simply smogger emissions engines since at least 72 , hell even the 70s truck 400 engines were only 175 horse(LF4)
good luck!
Old Dec 17, 2007 | 11:55 AM
85T/A's Avatar
well im not gonna throw my 305 heads on the engine im putting alot of stuff into i was just thinkin about putting the heads on the junkyard 350... think itll give me any gain?
Old Dec 17, 2007 | 05:23 PM
85T/A's Avatar
any input on my last post?
