intake manifold help
Old Dec 19, 2007 | 11:20 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
ok, this is where i started:
https://www.thirdgen.org/forums/tbi/...-out-bolt.html
and this is where i am now:
i'm about to go out today and find an intake manifold to replace mine, it's for my '88 TBI LO3, i may just keep it incase i need it and attempt to fix it anyways. New question on this 2nd intake, i was told that i should create studs for the water neck. Can someone explain in explicit steps how exactly to do this. I know about the stud rods that come in like 2-4 foot lengths, just how do you suggest cutting them to length without screwing up threads, how do you suggest keeping them in the manifold...would locktite be enough? any suggestioins and warnings?? and does anyone happen to know the size of the stud i need. Thanks all that can help me out!!
Old Dec 20, 2007 | 09:41 AM
Damon's Avatar
Re: intake manifold help
Cut the stud to length and then grind off the sharp edges of the end threads at a 45* angle on your grinding wheel. It'll screw right in.
Don't know if studs are really needed there unless you want to keep something sticking out the top to attach grounds or something. To keep bolts from freezing up in the threads just apply some anti-seize to them before you screw them in. Aluminum has a nightmarish ability to freeze onto threads if you don't apply anti-seize.
Old Dec 20, 2007 | 11:06 AM
84redta's Avatar
that's my issue now, i broke a bolt off that attatches the waterneck and now i gotta go pick another intake up, because at the moment i'm not interested in drilling it out. Someone suggested creating studs because if they get stuck it's no big deal, and being the nut is going to be above the water neck, even if it gets a little seapage and rusts the stud in there or as you said aluminum likes getting bolts stuck, i wounld't have to worry about it because the bolt would be easy to get pb blast in and most likely would come out. where can i get the anti-seize stuff??? If i go to the counter of my advanced auto would they know what i'm talking about?
Old Dec 20, 2007 | 02:12 PM
chesterfield's Avatar
Car: Pontiac
I have an intake I'll sell you for $20 + you pay shipping. I'm all the way over in 93456 CA. Part number is 14102182. PM me if you want it.
Old Dec 20, 2007 | 07:18 PM
Damon's Avatar
You can buy it just about anywhere- Pep Boys, your local auto-parts store, etc. It's a grey paste in a grey bottle. You smear it on with a little brush built into the cap. One bottle will last you 10 years. Just "paint" the threads- don't glob it on.
Old Dec 20, 2007 | 08:29 PM
84redta's Avatar
thanks, went to the parts store and they had exactly that. anybody else thinking the stud idea is worth it??? i got a couple people on the other thread to say i should do that, but i don't want to do more work and more $$$$ than i have to. Thanks damon on the heads up!!
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
