accelerator cable lubrication?
Old Dec 20, 2007 | 08:56 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
again, sorry for all of my questions, i did not post this with my other post because they are totally unrelated.
my gas pedal is really hard to push, could i lubricate the throttle/accelerator cable and make it smoother? it doesnt catch or anything and might not even
need anything, i am just not sure.
the only things i have to comoare it to is my old carbed 305 and my 4.6L mustang GT and an older 5.0L mustang and it is just way harder to push.
sorry if this is not in the proper forum and if it isnt, moderators kindly move it. thanks.
Old Dec 20, 2007 | 10:26 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: accelerator cable lubrication?
Well it only takes about 5 minutes to disconnect. So take it off, and check for the feel by hand. Then drop a couple drops of oil down the sleeve. Can't hurt. Move it around. See if it is helping at all.
Also make sure you don't have too much return spring.
Old Dec 21, 2007 | 05:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mine gets stiff in the winter. Makes it hard to push the pedal without the car jumping. I haven't even tried to lube it yet. Let me know how dennis's idea works.
Old Dec 21, 2007 | 08:04 AM
impaled's Avatar
i will work on that tomorrow. it is winter here down here in florida, but its not really that cold. thanks.
Old Dec 21, 2007 | 08:25 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I have used some stuff called DRYSLYD (i think thats what it was) on cables and seat tracks works real well. It is GM stuff they used for that purpose. It is a spray that leaves a dry i believe graphite film when the liquid evaporates, very similar to the lock thaw stuff you can get for door locks.
Old Dec 21, 2007 | 09:02 AM
83Chevy__Camaro's Avatar
haha winter in florida is still paradise, its winter here, the temp is -48 below average right now
Old Dec 21, 2007 | 10:36 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It's probably the throttlebody rather than the cable. Might need cleaning.
Old Jan 23, 2010 | 03:29 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
I know this is an old thread but the info is still useful for those with the same problem.
I have an 87 Formula with a 4bbl carb. I put in a new accelerator cable and it was really stiff. The bracket it mounts to made the cable attach to the carb at an angle. From the bracket to the carb that is, it went at an angle. So the inner plastic tube from the rear of the cable attached to the bracket going into the outer plastic tube from the front of the cable where it mounts to the throttle was rubbing. I got the WD40 with the straw attached to it, pulled the outer cable housing to one side, enough to get the WD40 to spray in there and that worked. Now the pedal pushes easier than it did with the old cable.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
