can this handle 6000rpms
Old Dec 20, 2007 | 07:54 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Stock iron crank, lt4 powdered metal rods, and cast pistons. comp xe274 rhs vortecs and a rpm air gap will be going into this motor plan on making power to 6000rpms just curious can the block take it.
Old Dec 20, 2007 | 08:10 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: can this handle 6000rpms
Yes it will.
Old Dec 21, 2007 | 02:41 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i've pushed a cast 383 with forged pistons to 7k on a burnout.. power peaked at 5800.. 383's dont like to rev either.. you should be fine.. just make sure your tuning is good and prevent detonation..
Old Dec 21, 2007 | 03:09 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
It will take it. I know a guy that takes a stock short block and spins 8000 RPMs every weekend. and I spin my 355 to 6000 RPMs and it has a cast crank and rods.
Old Dec 21, 2007 | 01:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Was the rotating assembly balanced?
Old Dec 21, 2007 | 02:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah as long as its balanced...i plan to take my L98 to over 6000 occassionally with a safe conservative tune
Old Dec 21, 2007 | 06:17 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
its a gm performance part crate 350 internal balance
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
