Anyone have tricks to get Block #'s??
Old Dec 20, 2007 | 09:19 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
I tried for like half an hour today to get the numbers off my block i tried everything but i could NOT get them. maybe my head is too big?? i was literally trying to stuff my head down there and could not read it. anyone have a trick to beaing able to get at that number to read it? maybe ill find like a 4 year old kid with a really small head and stuff his head in there?
Oh and i really want to avoid taking off my hood
Old Dec 20, 2007 | 10:19 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Anyone have tricks to get Block #'s??
The last 3 digits are typically cast into the area right above the block drains.
Old Dec 20, 2007 | 10:22 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
what if you got like a mirror?
Old Dec 20, 2007 | 11:31 PM
Car: 84 Z28
Engine: carb 305
Great idea!! ill try that. I even have one of those fancy mechanics bendable ones geez...
Old Dec 21, 2007 | 12:49 AM
joshh44's Avatar
Engine: engineless
im glad to be of survice
Old Dec 21, 2007 | 01:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd guess it's 010
Unless it's a roller block, but I doubt that. My moneys on 010.
Old Dec 22, 2007 | 03:24 PM
Car: 84 Z28
Engine: carb 305
Ya i'm pretty sure it is too it's a blue block so it came from late 70's i had the same engine in the berli its iether out of a camaro or truck. Correct me if I'm wrong.
Old Dec 22, 2007 | 04:45 PM
joshh44's Avatar
Engine: engineless
i think i might have the same engine block lol i just bought a 010 block. 4 bolt main. someone has cleaned it but there might be afew flakes of blue around somewhere. its a 1977 engine. i looked up the numbers and says it came out of a truck, corvette, or camaro.
Old Dec 22, 2007 | 05:07 PM
Car: 84 Z28
Engine: carb 305
Ya theyre good blocks.. i would like to get the numbers to find out exactly where it came from tho my last 350 block and heads were from a 78 camaro but the heads i have now have a different symbol on them the last ones had two humps that were the same size and these heads have a small hump then big hump so im guessing i might have the truck block and heads. also the exhaust manifolds are shaped diffrently then the ones on the late 70's camaro
Old Dec 25, 2007 | 10:48 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Are you guys talking casting numbers?...The numbers (stamped code) on the front of the block will give you more insight as to exact year, application, HP rating etc. Check here for the decoders. http://www.chevy-camaro.com/
Old Dec 25, 2007 | 01:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Did they make an 010 blue block?
The casting number only gives you the basics of what the block is. It's good to tell you if it's a 4" bore block or a smaller bore 305 block. It's better to get the stamped code from the right front pad on the block in front of the passenger side head. These numbers can be hard to read as they're usually full of paint, dirt etc and if the block has ever been decked, the numbers will be gone.
Old Dec 27, 2007 | 12:11 PM
Car: 84 Z28
Engine: carb 305
Yeah this is my second 010 blue block.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
skinny z
Oct 5, 2015 06:23 PM
RS Reaper
Sep 27, 2015 07:04 PM
