Valve damage, Cause and Effect
Old Dec 23, 2007 | 11:46 AM
jos385536's Avatar
Car: 1992 Camaro RS
Engine: 305 HO
In my recent and ongoing troubles with my 92 'RS 305 TBI, I've discovered that one valve is stuck closed and two are hanging/catching on something as they open. All three are intake valves on the left/Passenger side. The driver side valves are fine. I've gotten two diffrent opinions so far. One says "bad gas" and the other says "bad valve job". What causes these things to happen and how can you tell the diffrence between them? I'm asking this because it is a new area of knowledge and I don't wan't to be ripped off by the ones who did my valve job last. I'm certian it's not bad gas because the valves were making noise even in proper adjustment from the first time I cranked the motor, and I haven't even been through a whole tank of gas yet (20 gal Tank). If you have or can find any pictures with comparissons of the diffrence that would be great. Thanks for your help.
Old Dec 23, 2007 | 12:02 PM
Guest
Guest
Posts: n/a
Re: Valve damage, Cause and Effect
I wonder if thats whats really wrong.
Anyway if it is, only thing that would cause a valve to stick or not move is physical damage.
Old Dec 23, 2007 | 12:40 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
check your spark plugs on these cylinders,if they are damaged then theres not enough clearance(possible causes ,shaved heads,pistons hitting valves,foreign object dropped in intake by accident,valve stems bent during head assy.later jimmy
Old Dec 23, 2007 | 03:10 PM
It is not possible for a valve to "stick closed". That's BS. Cross it off your list.
It is not possible for anything having to do with gasoline to cause valves not to move. Cross that off your list as well. All of the "gas" talk is BS.
It is not possible for valves to "hang" or "catch" on something as they open. Not only that, it is not possible to observe any such thing, due to the tension of the valve springs. Throw that out. More BS.
It is not possible for any feature of a "valve job" (which usually refers to removing the heads, disassembling the valves from them, grinding new seat surfaces on the valve and on the corresponding surface on the head where they seal, and reassembling everything) to cause valves not to move, open imperfectly, etc. Dismiss that thought. I'll let you figure out what kind of fertilizer that idea is.
What is REALLY going on here?
When you say "proper adjustment", describe how you know this.
What else has ever been done to this motor? Cam replaced perhaps?
Old Dec 23, 2007 | 11:01 PM
peanutmrpeanut's Avatar
may check piston to valve clearance. ps what size rockers do you have.
may want to also check cam pin. if this pin is missing may still run due to the bolt on the cam being there but may let cam move enough to bend the valves specialy during high aceleration.
Last edited by peanutmrpeanut; Dec 23, 2007 at 11:04 PM. Reason: Automerged Doublepost
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
355tpipickup
Sep 13, 2015 11:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
