engine balance - 1peice rms INTERNAL balance. why?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Why would someone want to internally balance a 1peice rms engine and use a flexplate such as this?
http://store.summitracing.com/partde...3&autoview=sku
Ring Gear Tooth Quantity: 153-tooth
Rear Main Seal Style: 1-piece
Engine Balance: Internal
Balance Style: Neutral
Notes: These are not stock replacements. For special internal 0 balance applications.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: engine balance - 1peice rms INTERNAL balance. why?
That's an SFI certified flexplate required for vehicles running 9.99 and quicker in the 1/4 mile.
My 540 is an internally balanced engine mainly because the 4340 stroker crank I needed wasn't available as an externally balanced crankshaft.
Car: '02 Z06
Engine: L33 5.7
The point i was trying to make is that its for a one peice engine without the batwing counterweight. Can you explain this benifit?
Car: 87 IROC L98
Car: '02 Z06
Engine: L33 5.7
OK I think I understand now, thats why my machine shop ground the counterweight off my flexplate.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
stock L98's are internally balanced but also have the flexplate wieght so its kinda both external and internally balanced
not sure if most 1 piece rear main blocks should be the same way or not
An internally balanced engine will be a longer laster better running engine. The reason to balance internally is to keep the crank from causing a bending harmonic that is hard on bearings etc. It its done externally you only have the front and rear of the hole assembly balanced by the small weights on the balancer and flywheel. If it is done internally you will have an even balance thought the entire rotating assembly and there for a smoother running more efficiant engine.
balance, balanceinternal, bbc, bending, engine, flexplate, flexplates, internal, internally, main, peace, rear, seal, th400, transmission
