Edelbrock performer heads?
Old Dec 23, 2007 | 04:32 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Hi, So I have been looking at a set of Edelbrock Performer aluminum heads 60859, They seem to be a pretty good set up, I would be looking at the ones already assembled for my 91 T/A L98 A4 setup, gonna put headers on, and already have a bigger Throttle body and maybe a bigger cam, not sure on all the specs, Are these heads any good?
Old Dec 23, 2007 | 06:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Edelbrock performer heads?
They're decent for mild engines, but Trick Flow 195s are better. So are AFR Eliminators, but they're more expensive.
Old Dec 23, 2007 | 06:50 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Where is a good place to find those?
Old Dec 23, 2007 | 08:01 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
And is there any downfall to running aluminum heads on a cast iron block?
Old Dec 23, 2007 | 10:00 PM
Kevin91Z's Avatar
Summit Racing sells the Trick Flow heads, because they are made by Summit.
We have been using aluminum heads on iron blocks for years. No problems.
Old Dec 24, 2007 | 09:29 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Well I think I am gonna go with Trick flow 195's.
Old Dec 27, 2007 | 09:53 PM
thegooseman's Avatar
Car: 1992 RS
How about those patriot heads?
Old Dec 27, 2007 | 10:06 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
go ahead and by the best heads you can afford and later on if you make(you will!) more performance upgrades, you'll have enough heads to handle it.
Old Dec 28, 2007 | 02:41 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Well, i guess I decided to go with the Patriot heads, The specs on them should be plenty enough, and they are a good price.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
