Really bad exhaust smell at start up
Old Dec 25, 2007 | 11:12 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Ok every1 there is a bad smell right when I start up my car. Smells like somethings burning. The smoke is a blue color but a few seconds after start up it doesn't smell or smoke. Is this something to worry about?
Old Dec 25, 2007 | 11:18 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Really bad exhaust smell at start up
If it only does it after sitting for a while like overnight it is probably just leaking valve guide seals. This is very common on a lot of GM heads. If that's what it is, I wouldn't worry about it much as long as it stops smoking after a few seconds. It's more embarrasing than anything.
Old Dec 26, 2007 | 12:05 AM
Engine: 350/350/LS1
Embarassing yes I still go to high school =O What can I do?
Old Dec 26, 2007 | 10:50 AM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
It still burns oil, fouls plugs, and leaves horrible deposits in the combustion chamber over time. you can change the seals and valve cover gaskets for like 50 bucks. just make sure you don't drop a valve (either push a small rope in through the spark plug hole, use compressed air, or turn the crank untill the cylinder you're working on is at the top of it's stroke), and you may want to use some sea foam afterwards if it's been doing this a long time.
eightsixseven
Dec 16, 2024 01:50 PM
bryan623
Mar 22, 2021 06:43 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
