Engine wont turn over
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
I just put my engine back in the car and finished tightening my steering column at the same time and the engine won’t turn over.
All the lights work, my windows roll down, and every thing. However my fog lights doesn’t turn on, and my headlights won’t go back down but the headlights turn on.
When I put the key to the on position the security light turns on for a few seconds and turns off, I think that’s normal though. But the engine light dose not turn on, I think that is supposed to turn on when the engine is not running.
I can’t find anything that connects to this connector under the steering column. (The picture below)
And could the battery be bad because it has been sitting for a year and a half?
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: Engine wont turn over
you said you tightened your steering column..did you have it out or something? did you do any other work under the dash where you may have knocked the safety switch loose from the clutch pedal?
Car: 89 GTA
Engine: L98 350
I never put the clutch swich in and it ran after i did the t-5 swap with out the clutch siwch. I just had to make sure iI had the clutch in before I started or the starter would move the whole car.
Car: 1988 Pontiac GTA
Engine: 5.7L TPI L-98, Headers, Flowmaster
Transmission: 700R4 w/shift kit
Axle/Gears: Stock, I think...
Hey Cambridge205,
I was seriously contemplating switching my GTA over to a manual transmission. Was the swap very hard to do?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take a test light to the selinoid
to the s terminal
have someone turn the key and the light will come on
if it doesnt then you have to go from there
to the s terminal have someone turn the key and the light will come on
Car: 89 GTA
Engine: L98 350
The swap was not too hard however you need to measure for the hole in the firewall from a firebird that already has a clutch. The hardest thing was to get the hydraulics properly bled. But that depends on luck for some people bleeding it by the slave cylinder works and I wish it did for me, and some times you have to do something like a backwards bleed. But the whole swap was well worth it! Till the engine busted on me
I'll try the test light. But I don’t have one right now. I'll get one when I get my battery tested tomorrow. But I’m betting its something to do with the steering column does anyone recognize that connector I took a picture of?
Car: 89 GTA
Engine: L98 350
I found out what was wrong. The signal wire was on the wrong post. And I had the starter tested when I found out "Oh there are two little posts on it..." Thanks for all the help and sorry for taking so long to update this post.
84z96L31vortec
Aug 20, 2017 12:16 AM
db057
Aug 11, 2015 10:11 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
