Where is the Coolant Temperature Sensor located?
Old Dec 28, 2007 | 12:27 PM
84KnightRider's Avatar
I am trying to replace the coolant temperature sensor on my 84 camaro with a swapped 350 but I have no idea where it is located. Pictures would be great ... please help I can't start my car!
Old Dec 28, 2007 | 12:41 PM
Re: Where is the Coolant Temperature Sensor located?
The CTS is on the water outlet. It has a 2-wire plug, yellow and black. Assuming of course that you still have the computer-controlled carb system on it.
A bad CTS will not cause a no-start. A runs-like-crap maybe, a Check Engine light for sure; but not a no-start.
What makes you think it needs to be replaced?
Old Dec 28, 2007 | 01:02 PM
Because I have trouble starting my car in the cold. I read about it and it said that based off the coolant temperature it determines the air/fuel ratio and it seems like I am not getting enough fuel to my engine to start it becuase it does turn over. In warm weather it starts perfectly fine.
Old Dec 28, 2007 | 01:19 PM
Does it have trouble starting? Do you pump the gas SLOWLY all the way to the floor a couple of times before trying to start it, like the owner's manual describes?
Or, does it have trouble turning over, which would be more a starter or other electrical problem?
Old Dec 28, 2007 | 02:52 PM
It has no problem turning over at all ... I've pumped the gas twice and the car would start. I would sit there for a good minute giving it a little gas to keep it from turning off but as soon as I switch it into drive it turns off. I try to start it again and it doesn't work.
Old Dec 28, 2007 | 03:45 PM
Not the CTS.
Sounds like the choke is not working. Probably all gunked up with the funk of the ages.
Get yourself a can of spray carb cleaner; clean off all the linkage on both sides of the carb, make sure it's all free to operate. See if that helps.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Bstrang6
Sep 8, 2015 04:29 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
