cam choice
Old Dec 30, 2007 | 09:53 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
cam choice
I just pulled a 350ci out of a 4x4 pickup that has been rebuilt. It has 10k mi on it and is in good condition. Can anyone give me a good cam choice that will work with the stock valve springs? It is a GM crate replacement engine about 165 hp, 4bbl, HEI. I have an edelbrock intake and carb for it, plan to get hedders and boost the spark. I really don't need 6,000 rpm on stock rods
never had much luck in that dept. 5,500 or less would be good.
Thanx sqzbox
Old Dec 30, 2007 | 10:21 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: cam choice
What year is the engine? Is it the old style with the flat tappet cam or the newer style with the roller cam?
roller cam = LT1 cam, used
flat tappet cam = stock cam, like a performer
With your low power intake and low rpm goal, I'd say you're looking somewhere in the neighborhood of an RV cam.
Old Dec 30, 2007 | 12:05 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Re: cam choice
The engine is old style, flat tappet cast #3970010 May be 2 or 4 bolt. I won't know for sure till I get the pan off.
Old Dec 30, 2007 | 12:12 PM
81caballero's Avatar
Re: cam choice
run a comp cams 268h. it can use stock springs, good idea to install fresh ones though, its a good all around performace cam and is a decent stock replacment cam.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
