trick to putting in 2 pc rear main seal w/crank in?
Old Dec 31, 2007 | 09:45 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have replaced my rear main seal once now on a new motor I built this spring. It started leaking right after I got the motor running and I remembered shaving a TINY bit of one of the seals off when I put it in on the stand.
So I replaced it and used the little tool and didnt shave any of the seal - but now its leaking worse than before!!!
Is there some trick to putting in 2 peice rear main seals that I am missing here?
Old Dec 31, 2007 | 10:16 AM
Re: trick to putting in 2 pc rear main seal w/crank in?
No, sounds like you did it the right way.
It's actually BETTER to be forced to do it that way, feeding the seal in endwise, than to just jam it straight in.
You should just loosen the other main bolts a bit to allow the crank some wiggle room. Use some motor oil or white lithium grease or similar on the seal, NOT sealer.
More likely, it's in backwards, such that the little grooves in the surface where it scrapes the crank, are wicking oil OUTWARDS, instead of INWARDS. Very common, very easy-to-make mistake.
Another VERY COMMON leak is between the bearing cap halves. There's oil pressure on the driver's side mating surface, and oil ABSOLUTELY WILL find its way between the metal surfaces, and especially right along the "corner" of the register cut, where the cap is chamfered. You should always put a very thin smear of sealer there, and a little extra in that corner; something that doesn't harden, like the Loctite/Permatex "thread sealer with Teflon".
Old Dec 31, 2007 | 10:21 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Thanks for the good info.
Old Jul 3, 2008 | 01:42 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ok - going to do this again this weekend.
So I put oil on the seals before I put them in - no rtv on the ends where they would meet?
Crankshaft turns clockwise foreward looking aft at the motor - so make sure the groves face the right way.
Smear some white thread sealant on the machined bearing cap surfaces where they contact the block, especially around the oil feed hole and the edges of the cap.
Did I get everything?
Thanks.
Old Jul 4, 2008 | 12:24 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Was the block line bored? If so there is a seal that is thicker on one side to compensate.
Old Jul 4, 2008 | 09:21 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
No - block wasnt line bored.
Old Jul 4, 2008 | 10:30 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
get the offset seal
the place where your seal was on the crank- it gets a little worn
sofa where ya been
missed you showing me the other side of the coin
Old Jul 4, 2008 | 11:38 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Jamon,
I dont understand what you mean by "the place where your seal was on the crank- it gets a little worn"
And I already have a seal.
Old Jul 5, 2008 | 06:05 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
there is a seal that moves the portion that touches the crank about 1/4 inch away from where a stock seal would touch, its only required if that part of your crank is worn enough to make it leak. i put rtv on the half ends of my seal and installed it with a 1/2" offset. no leaks for me.
Old Jul 5, 2008 | 07:02 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
crank is brand new last year and looks fine.
Old Jul 6, 2008 | 03:25 AM
QuickStyle's Avatar
Car: 91 Z28
just use the regular felpro blue seal then. part number BS40013
Old Jul 7, 2008 | 07:52 AM
jamon8's Avatar
Engine: 350 tpi
I put them in every block without silicon and they
NEVER
leak
period..........................................................
Old Jul 20, 2008 | 10:23 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Jamon8 - thats great but thats what I did and I had a leak.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Leggman1
Aug 6, 2015 04:15 AM
