wow 35 miles to the gallon
Car: 1992 RS
Transmission: 700r
Hey guys check this out I built one and now i am getting 35 mi to gal on my 305 http://waterpoweredcar.com/hydrobooster2.html
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Transmission: 4L80E/4L80E
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: wow 35 miles to the gallon
royslsbry, I check site out and saw a picture of a real dirty engine in camaro
how long have you been running this? you going to be stopping by any car shows?
how long have you been running this? you going to be stopping by any car shows? Trending Topics
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am sure they had a medium. "In most cases, nothing will happen; however, there is always the chance that the magnet could erase your data." Science is just that, SCIENCE "is the effort to understand, or to understand better, how nature works, with observable physical evidence as the basis of that understanding. It is done through observation of phenomena, and/or through experimentation that tries to simulate events under controlled conditions. It incorporates the philosophies of naturalism and employs reasoning."
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I think it's funny that you mention 150-250mpg being possible with patents out there. You would think a tree hugger would build one in his backyard and post it online
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Car: '82 Z28
I think Mythbusters said last night a soda can't explode in your car, I have proof otherwise in the form of a sticky mess.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
As for the origional post, i call total BS unless I see proof
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Oh, it'll work, to a point.
The problem with all of these ideas, is that it takes at LEAST as much energy input as you'll ever hope to get out. Ergo, lots of battery drain !
Then, the efficiency of the engine is only on the order of 27% or so, so you're only gonna get 1/4 of what you put into it at best.
Then, H burns MUCH faster than gasoline, so you'd need to retard timing to no more than zero degrees advance, and various other changes.
It's an old, but dangerous idea. NO SMOKING !
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
and as for the soda in a hot car, we had a nice stain in the floor of our old motorhome from where a 6 pack of soda went kabloom in the Alabama heat, i dont think there is enough tests in some of mythbusters stuff
there are plenty of things like that for the diesel market http://www.fitchfuelcatalyst.com makes a good product for big rigs that i have seen proven results, and also has a gas market out there
Car: 87 Camaro Z-28
89RsPower!
Yep. The site says 1978 Camaro Runs on Water but the picture is actually of a dirty truck or van (looked worse last night)
Anyway, would like to see the one in the Camaro.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
haha yeah just went back and looked at the link, apparently that car runs completely on water though.. I'd read through the article on it.. doesn't make much sense to me..
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Funny how royslsbry made such a short post documenting his information eh? Hmmm..
Uh huh.....
I also wear a tinfoil hat so THE MAN can't read my thoughts. We all know the "corporations" and the "government" are after us. They WANT us to be living in the stone-age wasting our dwindling resources. Down with the man!!!!
Uh huh.....
back in the day a guy in flordia invented a carb, or a something for a carb that would make a car get unheard of MPG and still have power, but the wonderfull people at ford bought him out and probably burned the patent for it
Since there has been no return to answer the reasonable questions, it's time for Mr.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
dbrochard
Oct 3, 2015 12:43 PM
86CamaroDan
Sep 29, 2015 10:08 PM
