oil pressure pegged
Old Jan 3, 2008 | 09:13 AM
huntman21014's Avatar
Car: 84 Trans Am
Engine: 350 mystery engine
oil pressure pegged
Hey all just bought a 84 Trans Am for 600 thats in greats shape with 124000 miles and a new radiator and alternator. I noticed that the oil pressure gauge wasn't working, it was all the way past 60 where 90 or 120 would be but wasn't at zero either so I assumed it was the sender unit and I was wondering If anyone could give me some advice on how to replace this. Ive searched the forum but havnt found anything for my particual model year. Other than this the car runs great and have historic tags run it every day. Thanks in advance
Old Jan 3, 2008 | 09:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: oil pressure pegged
Both of mine are always pegged when running.
I would ASSume that your sender would be a bell looking thingamajig located on the top rear drivers side of the block behind the intake manifold.
Old Jan 3, 2008 | 09:20 AM
how to replace this
Rotate counterclockwise to remove.
Installation is the reverse of removal.
You may find that the wire is merely disconnected.
Old Jan 3, 2008 | 09:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
What sofa said.
Old Jan 3, 2008 | 09:24 AM
Car: 84 Trans Am
Originally Posted by Viprklr
What sofa said.
so no oil or anything will leak out?
Old Jan 3, 2008 | 09:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Not if it's where I said. You might get a drop from the sender but, no.
Old Jan 3, 2008 | 10:25 AM
Car: 84 Trans Am
does anybody have a picture of the old one or a diagram of what Im looking for because I think that I have found it but I am not 100 percent sure
Old Jan 3, 2008 | 10:40 AM
It's a sort of a can looking thing about 1½" in diameter and about 2" long, has a kind of somewhat pointed end where the wire plugs onto it, below and just to the driver's side of the distributor. It is mounted on a brass pipe fitting that screws into the top of the block right behind the intake manifold. It's almost directly below the wiper motor.
Make sure the wire is plugged in.
Old Jan 4, 2008 | 12:25 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's a pic: This one was removed from an 84 Trans Am
Hope that helps !
P.S. This one has 3 prongs / wires and was removed from a NON-Emmisions ( Canadian ) car
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
