305 to 350
Old Jan 3, 2008 | 02:26 PM
Grchan's Avatar
305 to 350
anyone have a complete list of things that would need to be done to take my 305 engine and make it a 350
Old Jan 3, 2008 | 02:55 PM
Re: 305 to 350
start of list
a 350
end of list
Old Jan 3, 2008 | 04:46 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
Re: 305 to 350
to clarify for sofa...
the blocks are actually different in that the water jackets are to close the the cylinder walls in a 305 to bore it out to 4". most other parts are interchangable. you can find 350 blocks for less than $500 at most any scrapyard, some will even have a complete pull for around that or a little more. as far as the swap goes, it's a simple as taking out the 305 and putting in the 350, there is no other change.
good luck!
Old Jan 3, 2008 | 05:19 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 305 to 350
it's been covered on here countless times try the search button up top ^
Old Jan 3, 2008 | 05:31 PM
Grchan's Avatar
Re: 305 to 350
thanks
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
