Best block for TPI build-up?
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I'm looking around on craigslist for a 350 engine/block for my iroc. I'm seeing several '90s vortech motors from pickups and stuff. Are these blocks a suitable replacement for my TPI 5.0 block?
Transmission: 4L80E/4L80E
A Vortec block would be fine. But, I don't know anything about a vortech block.
Engine: tpi 305
Re: Best block for TPI build-up?
Sounds like you know at least a little bit. Are they hyd roller compatible?
The '96-up Vortec truck engines have roller lifters. They are Gen I type blocks, same as '87-up one-piece rear main seal roller lifter passenger car engines. They'll have PM rods as well.
A pretty good base for an engine build, whether TPI or something else.
Engine: tpi 305
Exactly the info I'm needing. Will they all have vortec heads as I assume?
Yes, just be careful and make sure you're getting a 5.7 liter, and not 5.0 liter. They look the same externally.
Engine: tpi 305
Good point. I'll be sure and check bores. I hadn't heard of a vortec 5.0, but I guess someone out there could make one and try to pawn it off to some sucker. Any idea what side the dipstick is on on these engines?
The 5.0 Vortec was the "standard" V8 for those years trucks.
Dipstick is on the passenger side.
Engine: tpi 305
Sounds like I'd better be extra careful. I can get my TPI manifold on there can't I? I know I can get a $500 vortec manifold from S.D., but I'd rather not waste the money if I don't have to.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
No, your intake won't fit.
The only real negative about vortec heads is the bolt pattern. You must buy an aftermarket TPI base to run your TPI on those heads.
evilstuie
Jan 9, 2020 08:29 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Sanjay
Aug 12, 2015 03:41 PM
