plug wire question.
Old Jan 5, 2008 | 12:09 AM
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
plug wire question.
Well ive had 2 pairs of Borg Warner wires in less then 6k miles. Last time I bought the oem replacement size I think 7.5mm,they were fine for a few thousand miles and then slowly started noticing misses at idle. I went out one night and noticed they were arcing bad. I replaced the wires cap and rotor (didnt touch the plugs since they were only 3k miles old). Well lately ive been noticing progressively worse idle so I went out again and misted some water and they are arcing all over near the boots. Has anyone else had troubles with these wires? Could having a miss for that long foul the plug and could that attribute to the bad idle also? I think im just gonna do a full tuneup again with either MSD or Taylor wires and AC delco plugs of course...also are the made for you looms worth it? thanks guys.
Old Jan 5, 2008 | 04:24 AM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Re: plug wire question.
I replaced my wires on my 93 F150 a few years ago with Borg Warners. It ran great but noticed one night that all around the plug boots was a faint purple glow. Corona effect? Not the beer! Anyway it didn't cause much of a problem except listening to AM on the radio. Don't know what I could have done to cause it because I replaced the plugs at the same time and used silicone in the boots. Got Borg Warners on my car now and don't notice the problem.
Old Jan 5, 2008 | 07:49 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
many O.E.M. wire sets , graphite/carbon core start to deteriorate from date of birth . a good silicone metal core set will make a world of difference . i am useing M.S.D. 8.5 and love them . Acell is also good . spend a few extra dollars and get the good stuff . you won't be sorry .
Old Jan 5, 2008 | 10:03 AM
I use Taylor. I highly recommend them. This exact set http://store.summitracing.com/partde...rt=TAY%2D73051 They alow you to easily duplicate the correct OEM routing, so they don't touch exhaust parts and burn up.
Old Jan 5, 2008 | 01:25 PM
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
Awesome. Had my eyes on a set of Taylor wires since ive heard a ton of good reviews on them. Should I be ok with any name brand distributor MSD,ACCEL etc?
eightsixseven
Dec 16, 2024 01:50 PM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
