which is better? part 2, with a 2nd ?
Old Jan 5, 2008 | 01:22 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
another question is whihc is better to hav, a v belt system or a serpiteen belt(sp)? or does it boil down to personal prefence also is it nessary to clean the pistion tops to get the carbon off? if so then how do i clean them? i mean i can clean with the pistions at the top or do i hav to take em out? and if i take em out, i hav to rebalance the engine again? (atleast thats what im told, but im starting to really not believe the mechinics here)
Old Jan 5, 2008 | 09:19 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: which is better? part 2, with a 2nd ?
It doesn't matter which belt drive system you use. The serpentine system is easier to work on and maintain because there is only one adjustment and the tension is set by the tensioner. You probably get more life out of your accessories from not over tightening them and certainly longer belt life. Of course, if you actually know how to tighten belts, then it's not a problem...
If you are tearing your engine apart and you take the pistons out, clean them by blasting them with walnut shells or glass beading. Be careful not to damage the connecting rod or the piston. I prefer the old 3M green scrubbie pads and some elbow grease, myself... If you are leaving the pistons in, then you are probably better off putting the engine back together and running something like the GM top end engine cleaner or similar.
Old Jan 5, 2008 | 12:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What was your origional post? I think I remember reading it but I forget.. what are you trying to accomplish?
Old Jan 5, 2008 | 02:33 PM
DARKmj16's Avatar
Engine: 305 tbi
ya my first was which was better, timing gears or chain,
but if i take out the pistions would i hav to rebalance anything? also is it really nessacry to clean the carbon off??
thank for the help you guys r giving me
Azrael91966669
25
Jun 20, 2017 04:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
