battery at 14.75 vdc but engine wont turn over please HELP!!!
Old Jan 5, 2008 | 03:21 AM
bmfIROC-Z's Avatar
Well ,i started my iroc about 5 days ago and it started fine just like it always does and i was organizing my garage a little tonight and decided hey what the heck lets fire up the iroc ,well i got in and turned the key and all it would do is click(starter is engaging but not turnin the engine over) so i swapped the battery out of the womens car thinkin the battery was low on juice from being cold and sittin and same thing just clickin' so i put a volt meter on the battery and it read 14.75 vdc ,then i jacked it up and tapped on the starter a little still nothing ,so then i turned the engine over by hand thinkin maybe the starter somehow got jammed in the flywheel i tried it again and still nothing but clickin' is it possible the starter motor could have took a crap just sitting there? could the power steering pump lock up and keep it from turnin over?is there any fuses or relays that could of burned out?cause' it'll click all day long but it isnt even tryin to turn over at all and the lights dont even dim when tryin to start it,also i recently removed the evac canister could that have anything to do with it?ANY INPUT WOULD BE VERY APPRECIATED ,PLEASE HELP !!! THANKS IN ADVANCE
Old Jan 5, 2008 | 08:28 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: battery at 14.75 vdc but engine wont turn over please HELP!!!
most likely a bad starter or a crappy ground.
Old Jan 5, 2008 | 09:55 AM
DA88TA's Avatar
Car: 88 trans am
Engine: 305 TBI
Transmission: auto
Check all your connections. I drove my blazer to work no problems and everything worked perfect, shut it off walked inside for 5 minutes came out and tried to start but just got the clicking noise, Battery was fully charged but found the positive battry cable had corroded thru at the starter end, replaced cable and all is well.
Good luck!
Old Jan 5, 2008 | 02:36 PM
bmfIROC-Z's Avatar
pulled the starter off and cleaned all connections,bench tested the starter everything was fine so i put it back together and it fired right up ,must have been just a bad connection or something ,anyway thanks for the replies guys.
Old Jan 6, 2008 | 05:35 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i had the exact problem on my old 87 305 and all it was was a bad ground/connection.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
