"Gorilla snot" - what and where do I get it?
Old Jan 10, 2008 | 01:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I even heard of this product in a book I was reading while killing time in a bookstore the other day - I have yet to see this product on a shelf somewhere. ( Imagine the labeling picture, that would sell itself...)
What's it's real product name, and would anyone recommend me using it to 'glue' my summit differential cover on the back? The last few times (using RTV) it still wanted to weep out some fluid.
Old Jan 10, 2008 | 01:45 PM
Guest
Guest
Posts: n/a
Re: "Gorilla snot" - what and where do I get it?
Gasgacinch
3M weatherstrip adhesive
Either or works.
I use a gasket on my rear, never had a leak issue.
Old Jan 10, 2008 | 01:51 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Or give a hanky to an ape at the zoo, but don't tease the tigers...
Old Jan 10, 2008 | 01:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Originally Posted by madmax
Gasgacinch
Either or works.
ah, 3M weatherstrip adhesive, i'll check for that. Gasket for the rear - with...? Or do you put a paper gasket on bone dry?
Old Jan 10, 2008 | 01:59 PM
What madmax said: 3M 8001 (or, 8008 is the black version... people call that "bear sh**")
I use either silicone or the paper gasket on rear ends, just whatever I have handier. The gasket hardly ever leaks anyway, no matter which you use. The seals, rubber plugs in covers that have those, faulty spot welds where the tubse go into the pumpkin; those are where the leaks usually are.
Old Jan 10, 2008 | 02:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I have one of those aam aluminum covers from slp and never had a problem with it leaking, when I take it off I just clean the surface real good and put a bead of rtv around it.. never had a problem..
Old Jan 10, 2008 | 03:21 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
guerrilla snot is not sticky enough long enough. me and other drummers use it so we don't through sticks out into the crowd or an annoying lead singer. I suggest the black gasket maker. i used red high temp and it did not stick well.
Old Jan 10, 2008 | 03:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
I can't imagine it'd stick well to your sweaty hands, I doubt anything would...?
Alright, well i'm going to get some of the stuff for purposes yet to be determined, and i'll try using my paper gasket dry then. I've used red and black permatex and neither one worked perfectly. It just weeped enough out of the bottom to get my hands dirty when I was down there. I'll check the pipe plugs in the cover as well.
Old Jan 10, 2008 | 04:07 PM
ryan91rs's Avatar
Transmission: 4L60
off topic but you put it on the sticks and a tiny bit in your palm.
Old Jan 10, 2008 | 07:44 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
hey sonix, just use black rtv.holds great no leaks,been on mine over two years.the blue rtv will actually let oil soak thru it.later jimmy
Old Jan 10, 2008 | 07:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, I was using black last time, and it leaked (a bit). I think i'll just sand the surfaces to be sure they're flat and CLEAN. Then put RTV on and let it skim up, then put the cover on and lightly tighten it. Then once it's fully cured wrench it down good.
mav75
Aug 31, 2015 12:16 AM
Dudeman1531
May 9, 2008 08:18 AM
92Z
Feb 12, 2008 01:36 AM
I H8 WWD
Feb 11, 2007 05:19 PM
