Single plane manifold to Duel plane with Divider
Old Jan 11, 2008 | 04:31 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Would it be possible to divide an Edelbrock Torker 2 into a duel plane using a divider? I have a 1987 L69 305 with 217*/224* @ .050" 112LSA and World 305 torquer heads. The intake is stock aluminium duel plane with ele q-jet. It has a 1" hole in the divider wall from the factory! I guess this acts like a single plane at higher RPM!?
any comments...... the intake was free!!
Old Jan 11, 2008 | 04:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Single plane manifold to Duel plane with Divider
It won't help anything to do that - might actually make things worse. If you look at a real dual-plane intake, its split into 4 runners each, two go to one side, two to the other side. Thats why it looks like some runners go overtop of others - they actually do. Its set up this way to work in conjunction wth the engine's firing order IIRC.
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
dusterbd
Sep 29, 2015 08:40 AM
