neutrL sAfety switch
Old Jan 12, 2008 | 09:13 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
im installing a new b&m pro stick shifterand i dunno which wires outa the stock switch go to the new safety switch... any ideas and will everything work like normal with the aftermarket plug? i nevr done it before and im cornfused thanks
Old Jan 13, 2008 | 09:45 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: neutrL sAfety switch
According to the schematic, and only IF these are the wire colors present at the plug:
Yellow and purple: starter circuit, closed together when in park or neutral.
Black with white stripe and orange with black stripe: ECM circuit, open when in park or neutral. Closed when in "gear".
Light green and dark blue: backup light circuit, closed together only in reverse.
(standard disclaimer: if you short something out, it ain't my fault)
Old Jan 13, 2008 | 01:17 PM
Engine: 355
so just hook up the yellow and purple to work?
Old Jan 13, 2008 | 01:44 PM
Engine: 350 4BBL
To work the starter, yes.
The other ones wouldn't be there if they weren't needed.
If your car no longer has an ecm, you could leave "Black with white stripe and orange with black stripe" disconnected. It may be tied into the cruise control also. If so, it wouldn't work afterwards.
The last 2 could be left disconnected if not having backup lights doesn't bother you.
Old Jan 13, 2008 | 06:14 PM
Engine: 355
i have the ecm still, but im thinking that it only reads the ecm if them are connected to tell it what gear your in... so if just the yellow anpurple hooked up i should be able to drive it right?
Old Jan 14, 2008 | 02:58 PM
Engine: 355
does it matter where i connect the purple or yellow wire on the switch?
Old Jan 14, 2008 | 07:13 PM
Engine: 350 4BBL
If it has only 2 terminals, no.
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
