flexplate issue...
Old Jan 14, 2008 | 10:10 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
flexplate issue...
I have two flexplates. Both go for internal balanced small blocks.
They are both for twopiece rear main seal.
The one that came off my stock 305 is smaller than the other one in diameter.
Why?
Old Jan 15, 2008 | 03:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
So the starter can be a little closer to the engine. Frees up room for things like exhaust.
Old Jan 15, 2008 | 08:32 AM
82Five-O's Avatar
Car: 82 Sport coupe
Re: flexplate issue...
but the starter doesnt get any closer, it's bolted in the same spot. I am running the smaller factory starter tho.
If i run this flywheel, will my starter still be able to engage it?
Old Jan 15, 2008 | 08:35 AM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
If its a 153 teeth you'll be fine
Old Jan 15, 2008 | 08:38 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
The smaller factory starter, with the bolt holes in line with each other - not staggered, will want the smaller flywheel.
Old Jan 15, 2008 | 08:40 AM
82Five-O's Avatar
Car: 82 Sport coupe
this is a smaller starter that is staggered
Old Jan 15, 2008 | 08:46 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Stock-type staggered starters use the larger one, 168 tooth.
Old Jan 15, 2008 | 09:29 AM
five7kid's Avatar
Yes it does, and no it doesn't.
I am running the smaller factory starter tho. If i run this flywheel, will my starter still be able to engage it?
As already stated, 153-tooth (the smaller) is the factory 3rd gen size. If your starter is the factory one, it will engage it.
84LsxZ28
May 17, 2020 02:21 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
