Help, Engine Issues
Old Jan 16, 2008 | 04:25 PM
cml11109's Avatar
Car: 89 Iroc-z Camaro
Help, Engine Issues
Hey Guys,
Well i bought a new intake manifold for my 89 iroc-z 305 TPI 5-speed manual, and installed it last weekend. Now after putting everything back together, the car is having a really hard time starting...after flooring the gas it actually starts and is pretty much idling with the pedal to the floor. once you take your foot off the gas pedal it completly dies! Any suggestions??? Any help, greatly appreciated..
Old Jan 17, 2008 | 11:54 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Help, Engine Issues
Check your fuel pressure at the rails.
Old Jan 17, 2008 | 12:01 PM
cml11109's Avatar
ok, i got the car running last night..messed with the distributor and timming...but now..after it starts and runs for a little while...and you stop it...it wont start again till it really cools down..the fans are running...everything seems fine...also..sometimes when releasing the clutch it just dies...am i getting closer to resolving this issue...or worse? after having the car not wanting to start in the first place..
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
