Melted my battery cables???
Old Jan 15, 2008 | 04:04 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
Ok so I was having a lot of trouble starting my car, battery problems mostly, so I kept charging it. And after trying to crank with the charger on it, the negative terminal would smoke a little.
Eventually my neg terminal connector burned in half and melted my neg wire, and halfway down it actually melted it into the positive wire
Do i just need to replace both cables? were they shorting to one another?
And don't the positive cable just run straight to the starter solenoid and nowhere else? I know how to run the negative cable.
Old Jan 15, 2008 | 06:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Melted my battery cables???
Change your starter too - its probably toast.
Old Jan 16, 2008 | 08:45 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
What he said :-)
Old Jan 16, 2008 | 08:58 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Dang dude, STEP AWAY FROM YOUR ELECTRICAL SYSTEM, you obviously are not qualified or get someone to help you.
Old Jan 17, 2008 | 12:46 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
last year I got a hard knocks lesson on starters. it started when my starter went bad... put a rebuilt one in. no shim (shoulda used one). starter worked for a month. then the replacement starter jammed and kept cranking. pulled so much juice from battery that smoke came from positive cable. car wouldn't turn off starter at the key. more smoke. more panic! finally used a wrench and unbolted battery cable! after calming down bought a another starter this time with shims. got some help. car has been starting fine since then.
I'm not saying you have a problem with your starter shim but you probably do have a problem w/ your starter and now battery cables. like the previous post you might want to get some help on that starter and battery cable replacement.
MM2Robinson
Oct 1, 2017 09:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
