Stock intake still has EGR attached... Remove?
Old Jan 16, 2008 | 08:52 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
As the title says I have the intake on my engine, and the EGR valve is just sitting there. But the new carb I just picked up hits the EGR valve and it just won't fit. At first I was thinking of just taking the EGR valve off and plugging the hole...
Will this cause any problems. The engine is all carb, with HEI. No computer, the engine is from a 1978 truck (350 5.7L). So, can I just take the valve off and seal the hole, or am I stuck?
I have another intake, an RPM performer but I just don't have the time to swap right now. Any ideas?
Old Jan 16, 2008 | 09:00 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Stock intake still has EGR attached... Remove?
Get an EGR block-off plate. Or, make one up..... you should be able to find one locally, or, from a pick-and-pull. Might be faster just to swap manifolds. The aftermarket manifold will certainly give you better performance.
Old Jan 16, 2008 | 09:03 PM
Daishi's Avatar
Time is the huge factor though, I work and I don't have a proper shop. So I only get about an hour a day to work on the engine. If I pull the EGR valve off, and just block the open hole it should be alright?
Old Jan 16, 2008 | 09:14 PM
There are 2 open holes. Both must be blocked.
You'll notice that one is easy (a circle); the other is a bit more of a challenge (a rectangle).
Get, or make, a blockoff plate.
"No time" won't change the reality you're facing. Like I tell my (adult) children, spend your limited time finding ways to get it done, not spend your limited time dreaming up excuses for why you can't get it done. In the end, it's either done (with no excuses) or not (WITH plenty of perfectly good excuses). Which one fits your needs better?
SIR NO EXCUSE SIR!!!!!!!
Old Jan 17, 2008 | 09:49 AM
Daishi's Avatar
That sounds alright,should I be blocking off each hole seperately? or just a plain cover over the top?
Old Jan 17, 2008 | 10:56 AM
A flat cover plate is easier.
1992rs/ss
Jan 31, 2025 05:10 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
