going to run LT4 springs and retainers but what about (retainer to seal clearance?)
Old Jan 18, 2008 | 06:06 AM
Parts4sale's Avatar
these springs are good to 525" of lift if i wanted to run a bigger cam
would LT4 springs and retainers work with out hitting the vavle seals on a cam just under 525"? also with LT4 locks reainers and springs. do i need shims? if so what size? thanks guys
Old Jan 18, 2008 | 09:19 AM
Parts4sale's Avatar
Re: going to run LT4 springs and retainers but what about (retainer to seal clearance
this is on a stock type L03 motor with stock l03 heads
Old Jan 18, 2008 | 04:34 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Nope, still have to do machine work. The only way to get more lift without machining is to use .050" offset locks, and then use .050" shims to get your installed height back up to where it needs to be. I don't recomend this unless you take your time and double check your clearances and installed heights to make sure that everything is ok.
Old Jan 18, 2008 | 04:57 PM
Parts4sale's Avatar
thank you for your replie
well i need new springs and i have LT1 cam, but will LT4 locks reainers and springs work on stock L03 heads? all just be putting down 460" lift, will i need shims? if so do you know what size? thanks
Old Jan 18, 2008 | 09:26 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
you shouldnt need shims with stock retainers and locks. although those springs might come with a different recommended install height so double check that.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Street Lethal
Aug 13, 2015 08:28 PM
anesthes
Aug 8, 2015 09:37 PM
