Correct Pushrod Length Question
Old Jan 19, 2008 | 01:02 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I need help with pushrod length advice.
Heres the deal. The cam is a hydro roller.
Comp cams says the cam needs .030 preload as ideal.
I am running stock hydo roller lifters. I bought an extra, took it apart, took a 9mm shell casing turned it down on a case lathe and inserted it into the body and reassembled without the spring. The shell casing (spacer was cut to length to allow the plunger to set .030 down from the snap ring which should be perfect per comp cams as for mocking up a lifter as running with "ideal preload".
Now the issue...
My installed height on the valves has some variance. I could not find my feeler gage but with a strait edge and eyball I guess the variance is about .040 with the exhaust valve being shorter. I will take better measurements tomorrow.
Is this enough variance to warrent two different length pushrods. To set the rub pattern perfectly on all valves would require 16 different length pushrods.
To determine proper length..
I have used an adjustable pushrod and a plastic "mock rocker arm" pushrod length checker.
The checker will measure that I have the correct length pushrod, on certain valves with a 7.192 OAL pushrod...
But the wear pattern (roller tip witness mark on sharpie painted valve tip) says they are too long. Does the wear pattern need to be dead nuts center?
Adjustable pushrod set to about 6.90 will yield good wear mark, but is determined to be too short per plastic checker.
How critical is this measurement. Camshaft is a COMP CAM XR294HR 242/248 @.050 and lift of .540 /.562.
Old Jan 19, 2008 | 01:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Correct Pushrod Length Question
The location of the witness mark isn't as important as it's width. The correct pushrod length is the one that has the rocker tip moving back and forth across the valve stem as little as possible over the full motion of the cam. Pushrods are available in .100" increments, so don't get too hung up over trying to get an exact length smaller than that.
Old Jan 19, 2008 | 11:57 PM
SDIF's Avatar
Thanks for the reply!
I checked again today with some week test springs vs the regular springs.
A length of 7.132 put the witness mark dead nuts center with only a thin rub line !
I also checked piston to calve clearance and the intake was tight at .072 exhaust was over .125.
Engine has hypo cast pistons. Will .072 be enough clearance? I will check again tomorrow.
Old Jan 20, 2008 | 12:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're a little uncomfortably short on clearance on the intake side. It should be at least .080", preferrably more.
What method are you using to measure the clearance?
Old Jan 20, 2008 | 01:37 AM
SDIF's Avatar
Method for measurement...
Hydo Lifter modified to be fixed.
Set to zero lash / zero preload
Lightweight test springs.
turn engine over by hand push rocker arm down with fingers until it hits piston
Inset feeler gages
Old Jan 20, 2008 | 01:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So you're measuring clearance only at one point of the rotation, TDC? Or at many points, and taking the smallest clearance?
I'd use the play-doh method. That ensures you've got the smallest clearance.
Old Jan 20, 2008 | 05:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just make sure you don't use real play-doh for the play-doh method, it's too elastic. Modelling clay is a better.
Old Jan 20, 2008 | 06:13 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
You are going to be fine get your self some modeling clay and double check you will see you have more clearnce than you think. I use to check pisyon to valve like that had one real tight tried the clay method and found I had pleanty of room you are basicly throwing the cam timing out using that method.
Old Jan 20, 2008 | 06:57 PM
SDIF's Avatar
I am checking it at many points turning by hand. .072 was the tightest. I am going to do again tonight with deree wheel attached
Old Jan 20, 2008 | 07:42 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Trust me use modeling clay.
Old Jan 20, 2008 | 11:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're doing it with the timing chain on?
Old Jan 21, 2008 | 11:46 AM
SDIF's Avatar
Yes, The timing chain is on. I am checking it as if the engine would be running. How else can I do it. Is there another way?
Old Jan 21, 2008 | 11:49 AM
SDIF's Avatar
Ross,
Why will the clay method yield different results? I don't Understand the throwing the cam timing out statement.
I would rather not pull the heads off. If I do this will I have to replace the gaskets? The have not been run.
Old Jan 21, 2008 | 11:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
You're measuring clearance in perfect world conditions. I'd want to know what'd happen if the timing chain snaps, or skips a tooth, etc. I'd want the piston at TDC, then push the valve down until it hits the piston, measure the distance, subtract valve lift, and that'd be my number.
Old Jan 21, 2008 | 12:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The method you're using now is fine. When is your clearance the lowest? What heads and pistons are you using? Has the engine been rebuilt?
Old Jan 21, 2008 | 12:20 PM
SDIF's Avatar
Engine is a brand new ZZ4 shortblock never in a car.
Heads are AFR 195 with 62cc chambers. These were on an expired engine and now have new valves and new valve job.
Old Jan 21, 2008 | 12:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm surprised you don't have more clearance than that. What head gasket are you using?
Old Jan 21, 2008 | 04:53 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I got different results because the piston and valves all move together. I have used cams in the .650 to .680 range with out cuting pistons It does depend on your cam degine also I find the better pistons seem to have more clearance such as JE, SRP, Weiscos. And as for pulling the head if you dont have enough clerance you will have to pull the heads to have the pistons cut or change a cam to get the clerance you need.
Old Jan 21, 2008 | 05:09 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Now the issue...
pretty big cam for a 305 isnt it?
Old Jan 21, 2008 | 05:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A ZZ4 is a 350.
Old Jan 21, 2008 | 05:52 PM
SDIF's Avatar
Head Gaskets are FelPro 1003s
Cam is properly degreed per cam card. I checked open and close at .006 tappet lift and confirmed 106 intake centerline with degree wheel and dial gage.
Old Jan 23, 2008 | 10:32 PM
SDIF's Avatar
Guys, THANKS for all the great advice!
I used the clay method and ended up with plenty of clearance!
I gained about .100 on both valves.
I don't understand why the measurements came up so differently.
My next question is what do I do about reusing my Felpro 1003 gaskets. The engine was never fired. Am I ok to reuse?
Also what is the best way to clean off the thread sealer from the block threads and the bolts. It is still stickey.
THANKS A MILLION!!!
Old Jan 24, 2008 | 02:46 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Your not the first to do that as I stated before.Its all in the cam timing remember the cam moves at 1/2 the speed of the crank.
Old Jan 24, 2008 | 06:06 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Get some copper coat spray the head gasket both sides. Run a tap into all the head bolt holes to clean them and wire whell the bolts. Put some fresh sealer on the bolts and bolt it together.
Old Jan 25, 2008 | 07:38 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
realistically you need to shoot for .125" piston to valve clearance fyi.
~Couch
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
