Which of these cams?
Old Jan 19, 2008 | 03:50 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I looking to put a cam into an 86 305 TPI motor. The motor is all stock. The only upgrades I plan on doing to it is a set of headers. The car is used as somewhat of a daily driver. Im just looking to get some more performance out of the motor. Which of these cams would be best for my setup? Would I have to make any modifications to the computer? And what else should I do if I put one of these cams in? What kind of performance gains could I expect?
http://www.compcams.com/Technical/Se...umber=12-262-4
http://www.compcams.com/Technical/Se...umber=12-249-4
Old Jan 19, 2008 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 249 is hardly better than stock. The XE262 would be a noticeable improvement with no problems for the computer.
Get new valve springs & retainers while you're at it.
Old Jan 20, 2008 | 02:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Which of these cams?
Would I be ok with changing the springs without also changing the retainers?
Old Jan 20, 2008 | 04:05 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
itll be fine people here just frown upon stock retainers because theyre heavy and bulky.
Old Jan 20, 2008 | 10:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Will my motor be able to handle the lift of the XE262?
Old Jan 21, 2008 | 12:09 AM
five7kid's Avatar
With new valve springs, yes.
The retainer thing - stock exhaust retainers have a heavy rotator, which doesn't do much for you. It will lead to valve float, although with a 262 cam, probably won't be a problem as long as you don't use factory springs.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
