How much am i risking?
Old Jan 20, 2008 | 08:52 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I am going to be putting heads, cam, miniram intake, 3.70 gears, rebuilt 700r4 and a new torque converter. My question is will astock lower end with roughly 125k on it be able to handle the power increase. Right now i run prolly in a 13.8 or so range with good traction. I am guessing the combo could be a lowwwww 12. Anyhew you guys think itll be somewhat of a good chance to run it like that? If not is therea good affordable block I can use?
I reallly would like to just keep the same block, but if it aint gonna be safe then I will dump away.
Old Jan 21, 2008 | 12:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends more upon how high you spin it than the miles on it.
What cam & heads are you planning?
Old Jan 21, 2008 | 01:40 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: How much am i risking?
H/o i gotta find teh link. Not like ur really holding on but I am. lol
heads
http://store.summitracing.com/partde...RT%2D10321112P
cam
http://store.summitracing.com/partde...2D08%2D423%2D8
rockers
http://store.summitracing.com/partde...CA%2D1302%2D16
Old Jan 21, 2008 | 02:35 PM
five7kid's Avatar
5600 RPMs shouldn't be a problem for a stock shortblock. Heads might be a little too big. You're probably looking at about 375 HP.
Not sure about low 12's, but 12's should be obtainable.
Old Jan 21, 2008 | 10:41 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay do you mean 5600 rpms or 6500? Also while we were on the subject. I have been the biggest fan on s/c. If i were to install a miniram setup with a megasquirt ecm and buy a used s/c and run it like 8-9 psi would that be safe? Im just tryin to gather options before i dig myself into something I cannot get out of. The s/c and miniram would be on the stock heads cam....... Am i crazy?
draco
Oct 4, 2015 09:25 PM
TBIWorks
Mar 29, 2002 01:52 PM
stallone
Mar 19, 2001 10:05 PM
85f-bird
Feb 18, 2001 02:51 PM
TRAXION
Jan 26, 2001 11:41 AM
