modified 305 tpi .. fuel pressure / timing question?
Old Jan 22, 2008 | 08:24 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i just rebuilt my 91 tpi 305 motor in my camaro .. and added ..
summit racing vortec heads .. 1.94 intake .. 1.5 exhuast .. 170cc .. 67cc
edelbrock vortec tpi intake manifold
msd distributor cap / rotor
taylor 8 mm wires
comp cam 08-501-8 (212/218 .. 264/269 .. and around .480/.490 lift)
flat top aluminum pistons (5cc)
hooker 2055 headers / y pipe
bbk adjustable fuel regulator ..
now i started it and drove it down the street .. drove like crap .. no power
checked the timing .. and it was 0 .. so i set it to 6 btdc
idles good now .. but still drives kinda sluggish / dont think all the power is there ..
i dont think i got all the air out of the coolant system b/c the thermostat didnt open yet ..
sounds friggen amazing though ..
but what could cause this "sluggishness" ..
the fuel pressure is stock right now
would it be not getting enough fuel / or do i need to set a different timing
what fuel pressure should i set it at / what degree timing for the mods i have ..
i havent tuned it yet .. and probably wont for a little while .. but the comp cam guy said the cam will work fine without a tune at first ..
thanks
adrian
Old Jan 22, 2008 | 10:29 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: modified 305 tpi .. fuel pressure / timing question?
your tune is way off with your MAP system. buy the tuning equiptment asap and learn to tune thats the only way youll find the lost power from that combo. MAP isnt forgiving especially for all of those mods.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Kaweh
Aug 9, 2015 02:54 PM
