Losing my mind!!! Car won't start!
Old Oct 28, 2009 | 09:24 AM
  #51
old fart's Avatar
Re: Losing my mind!!! Car won't start!
Just wondering if you spun the cam drive chain or if it's just wore out.
Old Nov 5, 2009 | 10:30 AM
  #52
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Don't know if this has been posted, but have you checked the voltage on your TPS , and have you adjusted your IAC ?
Old Nov 5, 2009 | 11:44 AM
  #53
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Now that you've got your timing set and you know the MAF is good start with the basics. Clean the throttle body really well. Those get really dirty on the tpi and make it run like crap. While youre in there take out the IAC valve and clean that too. Also check all of your vacuum lines and set the tps to the proper voltage. These are common issues with the tpi that often times make it seem like you've got a more serious problem.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
