Valve Stem Seals
Old Jan 26, 2008 | 08:33 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Valve Stem Seals
What kind of valve stem seals should I get, the umbrella, o-ring, or the positive stop type?
Old Jan 26, 2008 | 08:51 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Valve Stem Seals
I installed the Umbrella type, and have had no problems with them. Work good to, engine has over 200,000 miles on it, and does not use any oil.
Old Jan 26, 2008 | 09:59 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Positives on the intake are best. You still want an umbrella on the exhaust. The best umbrellas are the premium fel pro's that are the high temp plastic type w/ rubber insert.
You use an O ring with both positive and umbrella type seals. It is not a separate option for seals.
Old Jan 26, 2008 | 10:52 PM
SLP_GTA's Avatar
by chance would you have the fel pro part numbers?
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
