royal purple users be careful
Old Jan 27, 2008 | 01:16 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
ok so always used royal purple without any issue mafe the switch quite some years ago and its never let me down...until now, was great to me, last change on the camaro about 1100 miles while checking it over i noticed it was real thin, smelled horrible and looked like it had been in there for 9k miles so i thought huh, dumped it and put more in with the filter and have watched it EXTREMELY closely well here i am 900 miles, bad burnt smell and looked nastier than the **** i pull out of the diesel,(this cars oil at 3k has always looked great up till the last 2 changes) had also noticed some valve train noise not normal for this car, so i took it to work after the emssions test and bought a case of quaker state(old mans ran forever in everything and my moms blazer has 185K and never so much as had the manifold off) so i start it up to leave and the valve train doesnt sound good at all, to the point i was debating driving it home,but was gonna have to wait a few hours to get it in on a lift(live 3 miles away) so it somewhat clears up, i baby her home and dump the oil, came out thin as hell, literally was like water, it was hot but still never seen it run out like that in all my years, did the change with my good ole fram ph5 and quaker and she started real quiet no noise when its hot nothing and for what i paid for 1 bottle of royal purple i can get 3 quarts of quaker my buddy tony had the same problems infact we think thats what caused his 496 to start tearing up bearing i'm not messin with it anymore i got almost 9k into this motor....not gonna risk it, be careful guys be real careful i dont know if i got a few bad batches or what but i've now switched back to regular old quaker state
________________
Old Jan 27, 2008 | 01:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: royal purple users be careful
Shell Rotella-T 10W30 in my truck.
Penzoil 25W50 in my race car.
Old Jan 27, 2008 | 01:23 AM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
________________
that sucks. my camaro needs a oil change and i was going to switch to royal purpal but im not goin to mess with it now
Old Jan 27, 2008 | 01:40 AM
Big Time's Avatar
I switched to the purp on my tired old 180K lo3 recently and the change was amazing.
It runs much smoother and easier now and the smoke from the valve seals at startup is maybe 1/4 of what it used to be.
It also runs a lot cooler and takes a lot longer to warm up to 220ish to where the fan comes on, and the temp drops quicker and lower that it ever did before when I start to drive for longer periods.
The oil pressure gage doesn't wobble around at idle anymore, either.
I decided to switch after using that gunky Lucas crap and the oil pressure nearly maxed out. I read a few threads about it here, which convinced me to drain it all and try a synthetic.
I'm not sure what happened to your oil, but you should have it tested to find out. RP has a good rep that I'm sure is well deserved. If they were no good, most car guys would know about it like we do about the Teflon additives and now that Lucas gunk.
Old Jan 27, 2008 | 01:47 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I use mobil 10w30 syn in the car and I just put quaker state 10w30 syn in the truck.
Old Jan 27, 2008 | 01:48 AM
Car: 1992 Camaro RS
Engine: 305 TBI
i thought royal purpal was good i havent herd enything bad about it til now. im not sure if i sould switch to it or not
Old Jan 27, 2008 | 02:19 AM
Car: 91 Camaro RS
Engine: TBI
thats exactly what i experianced a few years back when i switched, its been good to me but the last few and my other buddies experiance have sucked...i'm not trying to sway people but i did want to put it out there, hey i got a problem here, make sure yours is alright i'm sure most of us check our oil religiously but some dont and assume its good, and if you've ever worked in a shop you have seen 15k miles i didnt know i had to change oil jobs kinda thing, i am **** about my fluids especailly oil and i'm just not happy with what i'm seeing with it right now
Old Jan 27, 2008 | 02:30 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
4k on szme oil and no problems. You guys are crazy lol. J/k I am sadd to hear. I love royal purple.
Old Jan 27, 2008 | 02:45 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
personally i dont wanna eat the price for expensive oil when it turns to bite me in the *** its dumb, i just run castrol and change every 3k, oil is oil, with the exception of syn VS conventional, plus i'm totally cool with paying 3$ a quart when i need 5 of them lol id hate to pay for RP with this car
Old Jan 27, 2008 | 08:45 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I use royal purple 10W40 and it does what oil is supposed to do. Before you condem royal purple you might want to see how the quakerstate is doing in 1000 miles. I think something caused the oil to get this way rather than saying the oil was defective.
Old Jan 27, 2008 | 11:20 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i'll be another guy for 10w30 mobil 1 syntehtic, by far cheaper than royal purple, normal color and does the same thing....
i run pure one oil filters with mine oil comes out barely dirty after every 3k change.
then again i have seafoamed my engine recently and it is only about 45k on a rebuild
Old Jan 27, 2008 | 09:25 PM
Car: 91 Camaro RS
Engine: TBI
oh no i'm definately keeping a close eye on it for sure, i had a guy come in today complaining about the rp he was running in his duece, and another guy trying to get contacts for them cause he was extremely irrate about the condition of his gear oil.....i dunno maybe colorado got some crappy shipments or something
Old Jan 28, 2008 | 12:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Send a sample for analysis. That's the only way to know what's going on. Fresh and used would be best, do you have any of either left?
Old Jan 28, 2008 | 07:18 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
quaker state 4 dino oil in all the DD`s...mobil one changed thier formula last year but it used to be the only syn I`d use, now it`s am`s soil ...swear by the bible I took the last race motor apart after 3 years with 150 1/4 runs and 6-8 thousand HARD street miles....turned my stomach it was so nice (mobil one 15w-50)
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
camaro1185
Oct 26, 2015 06:51 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
