!!!!! i need help!!!!!! 1986 z28 camaro
Old Feb 1, 2008 | 04:17 PM
Mrs_Arenas's Avatar
Car: 1986 z28 camaro
Engine: v8 305 tpi
i just recently bought a 1986 z28 camaro and i dont know if its the water pump going bad or what but there is a ticken noise coming from the front of the car, and do fuel filters go bad on these camaros
Old Feb 1, 2008 | 04:47 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: !!!!! i need help!!!!!! 1986 z28 camaro
Is the car over heating? Is the water pump leaking? Is the ticking coming from under the valve covers? Fuel filters do get dirty and need to be replaced over time.
Old Feb 1, 2008 | 05:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Injectors often make a ticking noise. Normal.
Old Feb 1, 2008 | 05:07 PM
Take a piece of heater hose, stick one end in your ear, and use the other to listen to the various accessories and things, until you find where the noise is coming from.
Old Feb 1, 2008 | 06:54 PM
Mrs_Arenas's Avatar
Engine: v8 305 tpi
thanks ill try o and where can i order parts for my car?? any ideas??
Old Feb 1, 2008 | 09:36 PM
Parts stores, speed shops, Summit/Jeg's, junkyards, classifieds, eBay, GM dealer, .... the usual.
Old Feb 1, 2008 | 10:50 PM
Mrs_Arenas's Avatar
Engine: v8 305 tpi
thanks ill check it out!!!!!
how can i get better gas milage?????
sorry i got so many questions
what kind of chip can i get for my car?
Old Feb 2, 2008 | 05:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Start with a tune-up. Change all the fluids, filters, etc. A chip is useless if the car runs/performs like a beater.
JamesC
Old Feb 2, 2008 | 06:20 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ha ha well,chip and gas mileage normally don't go in the same sentence without the words "loss of" in between but welcome to TGO
Old Feb 2, 2008 | 07:53 PM
Goonv8's Avatar
My advice would also be to get the engine checked over and seviced, make sure that its got good oil pressure. Next, I'd make sure that it was breathing properly by looking at the exhaust etc. (Especially if its got all that anti smog rubbish fitted) In terms of better MPG, a lot of people don't even check simple things like tyre pressures which make a huge difference.
Last edited by Goonv8; Feb 2, 2008 at 07:58 PM. Reason: Didn't read the thread properly
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Frozer!!!
Jan 19, 2024 04:55 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
