Retro-fit lifter pushrod length
Old Feb 3, 2008 | 04:49 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I'm trying to find the correct length pushrod for my 383. I'm running a set of retro fit roller lifters, and am using a hi tech adjustable pushrod length checker. I always come up with 4 turns out which means I need a 7" pushrod, but this seems to be an odd ball size. Comp cams shows that I should be using something around 7.3". I'm putting 1/2 a turn of preload, do the lifters need to be pumped up? Anyone running these lifters and wanna tell me what length your running? Am also running a cam with a small base circle to clear the rods if that makes a difference.
Old Feb 4, 2008 | 09:04 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Re: Retro-fit lifter pushrod length
TTT no one is running a retro fit setup and can tell me what length pushrods there running?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
